MPC5644A EBI with the IS64C25616AL problem
haitaoliu
I check the EBI signal with a logic analyzer. The signal on the ADDR port is normal, but the signal on the DATA port is incorrect. No matter how to change the data, the signal on the DATA port do not change.
Is there something wrong with my configuration?
Attachment is my project and the external SRAM document.
Original Attachment has been moved to: EBI.rar
davidtosenovjan
You have incorrectly define address mask. Please attention to following document, section 5:
External Bus Interface FAQs
and this example code:
Example XPC564AKIT324S External SRAM test CW210
