I want to test my application that should run finally on a IMX6G0 ( with no L2C) on the EVK board that uses a IMX6G2 ( with 128K L2C). For testing I would like to disable the L2C on the IMX6G2, but I didn´t find where.
Any idea how to disable L2C and keep L1C still enabled?
Carsten Bode
Hi Carsten
seems this is not possible according to answer on arm communty
https://community.arm.com/thread/9723
Hi Igor,
I want to test if th IMX6G0 is fast enough for my application.
So I need a evalboard with the IMX6G0.
Carsten
