在使用FXLN8361QX轴输出,在X轴输出端只接0.01u电容,0g时输出电压为0.754V,通过100k电阻接入LM324反相端0g时输出电压降为0.683V。
Solved! Go to Solution.
Hi Yongjun,
Looking at your schematic, there is basically a voltage divider with the internal 10 kΩ resistor causing this voltage drop. To avoid this, I would suggest using a low input offset rail to rail op amp to act as a buffer.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
Thank you
Hi Yongjun,
I hope it helps.
Tomas
