iMX 6solo hardware register set and programmer guide
andrewwozniak
I'm developing new Linux drivers for the iMX 6solo and will need a detailed hardware register reference for its eCSPI. More specifically, I need to add SPI  "slave" mode support.
Can you please advise us on which specific iMX 6 technical references will explain the SPI hardware register set for software configuration and operation?
Much appreciated,
Andrew
saurabh206
Senior Contributor III
Hi Andrew
You can check attached document
Chapter 37 Enhanced Configurable Serial Peripheral Interface (ECSPI) Driver.
For hardware register detail check IMX6SXRM.pdf.
saurabh206
Hi Andrew
andrewwozniak
Hello Saurbh,
This is exactly what I was looking for.
-Cheers
