bitbake commond not found
steven_zhang
Contributor V
当我要编译image的时候,出现commnd not found。但我上次编译的时候却没有这个问题。
aravinthkumarja
Senior Contributor II
Hi stevenzhang
I found solution for your issue.
Do the following steps:
=> fsl-release-bsp$ source  setup-environment build-wayland
** Then it will automatically goes to build-wayland directory
=> build-wayland$ bitbake fsl-image-gui
Then now it's working properly.
Note: If this post answers your question, please click the Mark Correct  button. Thank you!
Rita_Wang
Hi Steven,
Our expert has given you reply, please have  a check. If any questions contact us easily.
Have a nice day
Dan
BiyongSUN
then bitbake
Freescale_Yocto_Project_User's_Guide.pdf
