Peter Goddard
K60N512 .data and .data_init definition.
Discussion created by Peter Goddard on Apr 1, 2016
Latest reply on Apr 4, 2016 by jeremyzhou
I am trying to resurrect my Freescale Tower TWR-K60N512 (MK60N512VMD100).
The IAR linker is complaining...
Linking
Error[Li005]: no definition for "__VECTOR_RAM" [referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\Kinetis\hello_world\RAM_128KB\Obj\
startup.o]
Error[Li005]: no definition for "__VECTOR_TABLE" [referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\Kinetis\hello_world\RAM_128KB\Obj\
startup.o]
Error[Li005]: no definition for "__BOOT_STACK_ADDRESS" [referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\Kinetis\hello_world\
RAM_128KB\Obj\vectors.o]
Warning[Lp012]: no sections with name .data included - special symbol .data$$Base (referenced from C:\Users\Peter Goddard\Documents\Freescale Tower\
Kinetis\hello_world\RAM_128KB\Obj\startup.o) will be zero
Warning[Lp012]: no sections with name .data_init included - special symbol .data_init$$Base (referenced from C:\Users\Peter Goddard\Documents\Freescale
Tower\Kinetis\hello_world\RAM_128KB\Obj\startup.o) will be zero
Warning[Lp012]: no sections with name CodeRelocateRam included - special symbol CodeRelocateRam$$Base (referenced from C:\Users\Peter Goddard\
Documents\Freescale Tower\Kinetis\hello_world\RAM_128KB\Obj\startup.o) will be zero
Warning[Lp012]: no sections with name CodeRelocate included - special symbol CodeRelocate$$Base (referenced from C:\Users\Peter Goddard\Documents\
Error while running Linker
The file startup.c contains the following snippet...
data_ram = __section_begin(".data");
data_rom = __section_begin(".data_init");
data_rom_end = __section_end(".data_init");
n = data_rom_end - data_rom;
The linker is using the standard file
$TOOLKIT_DIR$\examples\Freescale\K60\TWR-K60\GettingStarted\config\K60X_ram.icf
.data and.data_init are not defined in it so how do I define it?
Thanks in advance.
