What is the required accuracy for the regulator input to the LPC17xx?
lpcware-support
Senior Contributor I
The internal voltage regulator voltage will always regulate around 1.8V where the external input voltage can range from 2.4V to 3.6V over the temperature range of -40C to 85C.
Labels (2)
Tags (2)
