Hi ,
There is a question about flashing the f/w of K64F's IC,
when I finish to develop my mbed OS project, then I want to shrink the size of prototype, so i want to prepare a MK64FN1M0VLL12 IC and mount into my new prototype, it's a new layout PCB, and not using FRDM-K64F develop platform.
so, it comes to a question: How can I download the mbed OS F/W into the new prototype?
I am trying to using Kinetis IDE, it looks like the project needs to create a project then program it by using IDE, then I change to using keil uvision5 with Ulink2, it looks like the same as Kinetis like.
is anyone know how to solve this question?
Hi Hokins,
How did you use to flash the firmware to your previous prototype?
You can use an external programmer like a P&E Multilink or Segger J-link to program the MCU trough the SWD/JTAG connector.
Hope it helps!
Carlos Mendoza
Technical Support Engineer
