iMX6: graphic window and full plane alpha blending
Question asked by James Liu on Mar 31, 2016
Latest reply on Mar 31, 2016 by igorpadykov
Dear Sir,
     I have some confuse on the concept of iMX6 graphic window and full plane alpha blending, as you can set Graphic Window as full plane in the register "  IPUx_DP_COM_CONF_SYNC" ( set GWSEL=0;)
But the in the register below, it says,
"GWAV - Graphic Window Alpha Value
Defines the alpha value of graphic window used for alpha blending between graphic window and full
plane. The Value the number that writing to GWAV register. "
How about if  graphic window == full plane? how to blend??
BRs,
James
