FRDM-KW24D512 OpenSDA not responding
mattiastörnblad
Hi, after trying to update the OpenSDA firmware to jlink on FRDM-KW24D512 both OpenSDA and bootloader are not responding! Is it possible to unbrick it from another board?
Wilgaced
I do the same with 3 units, so i can recovery thanks to Erich Styger (mcuoneclipce)
folow the step in this link, i use P&E multilink (the green) it work great.
https://mcuoneclipse.com/2014/11/10/recovering-the-frdm-k64f-bootloader-or-cloning-the-program-of-a-...
Note: i can recovery because i buy 4 units.
ok if you dont have other board here the link to memory dump
booloader_frdm-kw24D - Google Drive
