Issue installing KDSK 2.0 in Kinetis Design Studio
martinfiset
I am following the instrructions from the Getting Started with KDSK document on how to install KSDK 2.0 in KDS.
First, I did build and downloaded my KSDK package from the NXP tool (for the FRDM-K22F board).
Then the Getting Started document says to go to "Install New Software" and browse in the KDSK folder to select <install_dir>/tools/eclipse_update folder and select the KSDK__Eclipse_Update.zip file.
Unfortunately, the "tools" folder of my KSDK does not have any "zip file".
Did I miss any step?
Here is what I am using:
OS: Windows 10, 64 bits
IDE: Kinetis Design Studio 3.2.0
SDK: KSDK 2.0
Board: FRDM-K22F
Hello Martin,
About "Then the Getting Started document says to go to "Install New Software" and browse in the KDSK folder to select <install_dir>/tools/eclipse_update folder and select the KSDK__Eclipse_Update.zip file." , this is the method for the KSDK1.x
version , for the KSDK2.0 version , please refer to here :
Using Kinetis Design Studio v3.x with Kinetis SDK v2.0
Hope it helps
Alice Yang
