Pinout detail required for PN532/C1
dhvanish_parekh
Hello Team,
I tried to found document that contains pin signal description for PN532/C1 NFc module but not able to find such related doc.
Kindly provide me document that contains pin out detail of PN532/C1 NFC module.
Your quick response will be appreciable here.
Dhvanish Parekh
ivadorazinova
Hi Dhvanish,
Please, see Pinning information, Pin description chapter 8,
here is datasheet http://www.nxp.com/documents/short_data_sheet/120112.pdf
I´m attaching you newer one, pin description is the same.
I hope this helps.
In case of any issue, please let us know.
Iva
dhvanish_parekh
Hello Iva,
Thank you for your quick suppport!
I want one more suggestion from you related to antenna.
We are planning to use external antenna with this module with u.fl
connector support.
Kindly let us know if there exist any antenna for same.
Thanks & Regards,
Dhvanish Parekh
Volansys Technologies Pvt. Ltd.
Ph: +91 79 40041994
Website: www.volansys.com
On Wed, Mar 23, 2016 at 5:21 PM, ivadorazinova <
ivadorazinova
Hi Dhvanish,
IPEX and Hirose both have this u.fl connector.
Please, see attached file.
Iva
