Frequent FSTAT[ACCERR] on the MC9S08PA4
jerrypierce
Hi all, Is it so common to get an FSTAT[ACCERR] when doing writes to EEPROM on the MC9S08PA4 that I should set up some retry steps to handle it or is a write to EEPROM generally considered something that doesn't fail unless there is a problem with the setup?
I realize though that in the latter case setting up retry steps isn't a bad idea. I'm just trying to figure out if I have something set up wrong.
