Hello, I am trying to set up encrypted communication between two T1024RDB via MacSec.
I followed the instructions of the MACsec Quick Start Guide but the established connection isnt being used (deauthenticated and dissacociated after short time even while sending data over that port) and no data going over the port is being encrypted. I use a netAnalyzer tool between the two boards to check on that. Full uboot log and commands to set up shown in appended log.txt.
How do i get it to work?
much appreciated,
Flo
Original Attachment has been moved to: Log.txt.zip
