Debugging T1024RDB using code warrior from reset vector
Question asked by veerendranath jakkam on Mar 22, 2016
Latest reply on Mar 24, 2016 by Adrian Stoica
In trace32 when we reset the board the debugger will give control at 0xFFFFFFFC (Reset vector)... from there we can execute instruction by instruction and we can see the surrounding opcodes....
how can we do the same in Code Warrior Debugger...
My requirement is
1) I will connect debugger to Board
2) Open Debugger window
3) Reset the board
4) After board reset,  execution stops at reset vector.
5) From there I should be able to execute instruction one by one...
6) I should be able to see opcode of current and surrounding instructions.
Thanks and Regards,
Veerendranath
