USB CDC Driver on USB-KW24D512 problem
luwan
I used the function in bsp, USB_Init and CDC_ModuleInit, meanwhile the board is working in PEE mode.
The enumeration completed successfully.
After enumeration, I tried to talk with the board via the minicom in Linux.
But there is not any response when typing in minicom.
The board is able to get SOF interrupt, but there are not TOKEN interrupt received.
Are there any problems here?
