I.MX6Q is Unable boot
lukegu
Hi Dear ,
       My customer uses the MfgTool burned the u-boot , the process is OK , and the printf is right . But It doesn't boot normally . Could you kindly help me to check this issue? Thanks a lot !
Original Attachment has been moved to: cfg.ini.zip
Original Attachment has been moved to: ucl2.xml.zip
Hi luke
for new board it is necessary to run ddr test
i.MX6/7 DDR Stress Test Tool V2.51
then rebuild uboot with new settings obtained from test,
modifying uboot *.cfg file. May be useful refer to attached
document Chapter 1 Porting U-Boot
