Hi, My EVB seems have some error. And the LED D1 keep lighting.
I had tried the reset switch many times and there is no help .
How can I bring it back to normal?
Thanks!
Thank you for your attention!
I had tried your solution . But I still can not solve this problem.
My problem seems different from the links that you give.
I use the S32 DS as the debug environment and the "multilink universal " as tools.
Besides, I can not find how to add the Slowreset option :
System.reset
SYStem.Option.SLOWRESET ON
SYStem.CPU MPC5748G
SYStem.BdmClock 4MHZ
SYStem.up
Thank you!
Qiang
look at this thread a try. If it does not help, please write me back.
How to debug multicore with S32 Design studio
Martin
Hi Martin,
The link really helps me solve this problem.
Thank you very much !
Qiang
