Nicolas DECROZE
MAG3110 output values
Discussion created by Nicolas DECROZE on Mar 17, 2016
Latest reply on Apr 22, 2016 by Nicolas DECROZE
I try to use MAG3110 sensor with an arduino due board.
I have a question about the output values and the link with RAW bit in crtl_reg2.
My configuration :
     crtl_reg1 = 0xC9
     OFF_X register = 0x00
     OFF_Y register = 0x00
     OFF_Z register = 0x00
When i "test" with a small magnet i have :
  • If RAW bit is 1 (ctrl_reg2 = 0xA0), the output values i have are between -32768 LSB and +32767 LSB.
  • If RAW bit is 0 (ctrl_reg2 = 0x80) the output values i have are still between -32768 LSB and +32767 LSB.
I don't really understand what is the effect of RAW bit...
When RAW bit is 1, the output values souldn't be between -20000 LSB and +20000 LSB?
Many thanks for help.
regards.
