SATA read speed gets worse in linux 3.14.52
Question asked by richardhu on Mar 17, 2016
Latest reply on Mar 18, 2016 by richardhu
Hello, all:
I test SATA performace on our custom board with intel SSD and figure out performance difference in kernel version.
My SSD is INTEL SSDSA2CT040G3.
The benchmark under windows 7 64 bit with CrystalDiskMark 5.1.2:
The test commad i use on target board:
echo performance >  /sys/devices/system/cpu/cpu0/cpufreq/scaling_governor
Write test:
echo 3 > /proc/sys/vm/drop_caches
dd if=/dev/zero of=tempfile bs=1M count=1024 conv=fsync
Read test:
dd if=tempfile of=/dev/null bs=1M count=1024
Test Result:
(Rootfs is buildroot)
linux 3.14.52:
Write:
1073741824 bytes (1.0GB) copied, 26.856296 seconds, 38.1MB/s
Read:
1073741824 bytes (1.0GB) copied, 13.097736 seconds, 78.2MB/s
linux 3.10.53:
Write:
1073741824 bytes (1.0GB) copied, 28.990223 seconds, 35.3MB/s
Read:
1073741824 bytes (1.0GB) copied, 8.182314 seconds, 125.1MB/s
linux 3.0.35:
Write:
1073741824 bytes (1.0GB) copied, 36.756555 seconds, 27.9MB/s
Read:
1073741824 bytes (1.0GB) copied, 10.264888 seconds, 99.8MB/s
As you see, the read speed is 30% worse in linux 3.14.52 then linux 3.10.53.
Any idea ?
BR,
Richard
