FRDM-K82F
FRDM-K82F
kentachang_melt
I buy the FRDM-K82F, I want to find the schematic of FRDM-K82F.
Please let me know where to find the FRDM-K82F schematic ?
Kenta
Robin_Shen
Hi Kenta,
You can go to downloads page of FRDM-K82F: NXP Freedom Development Platform for Kinetis K82, K81, and K80 MCUs and download the FRDM-K82F - Printed Circuit Board bill of materials and design files.
The schematic can be found in that folder named "spf-28748_b2.pdf".
Robin
kentachang_melt
Hello Robin,
Thank you so much.
The schematic "spf-28748_b2.pdf" is found.
Kenta
mjbcswitzerland
Specialist V
Go to
http://www.nxp.com/products/microcontrollers-and-processors/arm-processors/kinetis-cortex-m-mcus:KIN...
and do a search for FRDM-K82F and the first link is http://cache.nxp.com/files/32bit/hardware_tools/schematics/FRDM-K82F-SCH.pdf?fsrch=1&sr=1&pageNum=1
This leads to "Page not found"
Instead search just for FRDM-K82F and then it will lead you to the board's page: http://www.nxp.com/products/software-and-tools/run-time-software/kinetis-software-and-tools/ides-for...
The trick with the evaluation boards is that the diagrams are generally not found under documentation but instead under downloads. However the same download link leads also to a "Page not found".
Therefore the web site has a problem at the moment - in the meantime I am attaching the FRDM-K82F Rev. B2 circuit diagram as PDF which can be downloaded until the missing file is fixed.
Mark
See also http://www.utasker.com/kinetis/FRDM-K82F.html
