code warrior evaluation licence with Devboard
rachansingh
Planning to buy Kinetis KEA128 StarterTRAK dev board for some LIN learning/dev. how long is the code warrior license good for If I buy this dev board
ZhangJennie
normally the evaluation license longevity is 30 days. after that, codewarrior switch to special edition automatically.
CW10.6.4 for kinetis E family, special edition C source-level debugger/programmer—code and data size restricted to 32k limitation. this is also documented in CW suite reference guide, page 3
http://cache.nxp.com/files/soft_dev_tools/doc/fact_sheet/950-00437.pdf
does this answer your question?
Jennie Zhang
ZhangJennie
Jennie Zhang
