we are using a custom board, with Coldfire V2 processor, and external Spansion flash. earlier the board was using BDM interface, and programming spansion flash was easy using P&E micro CYCLONE MAX. however due to design change in custom board, currently we are using JTAG interface instead of BDM.
I have this query for programming external flash using JTAG interface, as P&E micro does not support programming from JTAG.
Does anyone know any tool available in market which can support programming to external flash with CFv2 JTAG support?
Thanks & Regards,
Kunal Gaur
Solved! Go to Solution.
Hello kunal
Sorry please be note that ColdFire debugging and programming can only be done with BDM. JTAG is only for scan testing.
Best Regards
Fiona Kuang
Technical Information & Commercial Support
Hello kunal
Best Regards
Fiona Kuang
Thank you.
Kunal Gaur
