Hi everyone,
I customized in my imx6qdls-sabresd.dtsi file .I added ntc sensor in place of gpio codd .below mentioned changed code.
gpio-keys {
compatible = "gpio-keys";
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_gpio_keys>;
power {
label = "Power Button";
gpios = <&gpio3 29 1>;
gpio-key,wakeup;
linux,code = <KEY_POWER>;
/* volume-up {
label = "Volume Up";
gpios = <&gpio1 4 1>;
gpio-key,wakeup;
linux,code = <KEY_VOLUMEUP>;
volume-down {
label = "Volume Down";
gpios = <&gpio1 5 1>;
gpio-key,wakeup;
linux,code = <KEY_VOLUMEDOWN>;
/*PIR and NTC changed for custom board gpio */
pir {
label = "pir sensor";
gpio-key,wakeup;
linux,code = <KEY_PIRSENSOR>;
ntc {
label = "ntc sensor";
gpio-key,wakeup;
linux,code = <KEY_NTCSENSOR>;
| make: Leaving directory `/home/vishwa/workspace/veera_checkout_mar10/coderepo1/custom_mar11/tmp/work/imx6_zcam_custom-poky-linux-gnueabi/linux-imx/3.14.28-r0/image/usr/src/kernel'
| NOTE: make -j 4 imx6_zcam_custom.dtb
| DTC arch/arm/boot/dts/imx6_zcam_custom.dtb
| FATAL ERROR: Unable to parse input tree
| Error: arch/arm/boot/dts/imx6qdl-sabresd.dtsi:141.39-40 syntax error
| make[1]: *** [arch/arm/boot/dts/imx6_zcam_custom.dtb] Error 1
| make: *** [imx6_zcam_custom.dtb] Error 2
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
Can you any body guide me.
Thanks & Regards
veeranjaneyulu
Hi veeranjaneyulu
suppose this could be some simple typo error, could you check
carefully listing (or remove piece by piece until error disappears).
For example below comment seems is not compelted:
/* | volume-up { |
Thanks Igor,
Below code commented and renamed volume-up and volume-down in place of i gave pir and ntc sensor names.
/* volume-up {
gpio-key,wakeup;
volume-down {
gpio-key,wakeup;
pir {
gpio-key,wakeup;
linux,code = <KEY_PIRSENSOR>; //error coming here
ntc {
gpio-key,wakeup;
The above error coming at bitbake linux-imx -c build time only.
Thanks every one the above issue solved.
