i.mx6 non standard LVDS display problem
andreykononov
i have LVDS display with 1280x480 resolution and when i trying to show some data on it (video or some app) i can see only 4/5 of data and 1/5 part of screen is black. I'm using linux from yocto jethro. This problem is not depend from kernel cmd, now i have
video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:dev=ldb,1280x480M,if=RGB666,ldb=di1 ip=none
but when i set other cmd, for example
video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24 video=mxcfb1:dev=ldb,1920x1080M,if=RGB666,ldb=di1 ip=none
nothing changed.
Can i change this situation by make some settings or make change in kernel?
weidong_sun
    Please try to adjust IPU clock source ! see following link :
Porting LVDS LCD With Low Resolution to i.MX6
It should be helpful for you!
Weidong
