Change the ov5640 register values from runtime
giritharanr
Hi ,
     I am very new to this.Hope i will get some  useful solution for my problem.
I am using,
     IMX6 DL and OV5640 camera sensor.
I am livestreaming two cameras together i.e (parallel and mipi) .For that i wrote gstreamer  C application.Everything works fine.Two cameras(Front and Back ) are streaming parallel..
But now i am using IR LED for one camera1(parallel interface).So for that while streaming in night time i get pinkish issue because of IR led.
So for that i need to stream that camera1 video in black and white.I can change the video Black n White by manually changing some register values in ov5640.c file.
By problem is based in light sensor i want to change the video in both black n white and normal colour.
So how can i do that one?
How to change the ov5640 registers at runtime from user space C application?
please help me to find some good solution?
Thanks in Advance!
With Regards,
R.Giritharan
Hi Giritharan
suggest to check linux documentation and community i2c tools link
https://www.kernel.org/doc/Documentation/i2c/
All Boards I2C-tools
