Not able to ping from LS1043A RDB board
manjunathmandya
I downloaded SDK 0.5 version, and compiled code, downloaded kernel.itb file to LS1043ARDB board, i connected a laptop to eth1 and  assigned IP to  eth1 ( now renamed as fm1-mac2 ), tried pinging, it displays network not reachable.
Am i missing anything here.
Manjunath
Note: I have attached logs generated from default image in RDB board and the image we build and executed.
Original Attachment has been moved to: Image_Build_log.zip
Original Attachment has been moved to: RDB_DefaultImage_Boot_log.zip
Pavel
I am working at this problem. Please wait. You can also create service request for this problem to NXP technical support:
How to submit a new question for NXP Support
Pavel Chubakov
manjunathmandya
Hi Pavel,
           Any idea what is happening here ? Any updates ?
Manjunath
manjunathmandya
Hi Pavel,
       I observed that it is sending ARP request and getting back ARP response, but no further action. Any idea to go ahead?
Manjunath
Pavel
Could you send dump for your current routing table.
Type the following command to display routing table:
# route
OR
# route -n
Pavel
manjunathmandya
Hi Pavel,
     Please find attached screen shot
Pavel
Look at attached file. Test your board using similar command sequence:
ifconfig eth0 IP_address of your board.
Pavel
manjunathmandya
Hi Pavel,
Thanks for reply, we did following steps
1) login as root
2) ifconfig fm1-mac2 169.254.140.233 ( With SDK 0.5 ethx as been renamed as fm1-macx )
3) ping 169.254.140.232 ( my laptop IP address )
it responds as
Network not reachable
Manjunath
