I.MX6 JRSDIDR TZ=1, MIDTZ, Job RingTZ
myungjinhwang
Dear NXP team.
I've seen JRSDIDR TZ=1, MIDTZ, Job RingTZ  as bellow in the reference menual. (IMX6DQ6SDLSRM.pdf)
     B.2.6 Job Ring Registers
     This section describes registers found in each of the job rings. A functional description of
     the job rings can be found in the “Cryptographic Acceleration and Assurance Module (CAAM)” chapter.
     If the job ring is allocated to TrustZone SecureWorld (JRSDIDR TZ=1), then the job ring
     registers associated with this ring may only be written via a bus transaction that has ns=0.
     Transactions with ns=1 for job rings owned by TrustZone SecureWorld will be ignored.
     B.2.5.4 Secure Memory Partition Owner Register (SMPO)
     When a Job Ring owner reads this partition from the address alias associated with the Job
     Ring, the value returned will indicate whether that Job RingTZ/owns the partition, another
but there is no register that i can read/write TZ bit and i could find the TZ bit, JRICID register In the LS1021ASECRM.pdf file.
Please give a guide this for IMX6.
Yuri
  Sorry, but the information you are requesting is treated as confidential info at this time and requires a signed NDA (Non-Disclosure Agreement). Naturally, we cannot discuss this with you in public anyway, this requires to be handled
as a Service Request (SR).
In order to enter a new request :
How to submit a new question for NXP Support
Yuri
