k60 mqx3.8 ulpi hs support with USB3300
Question asked by KYLE SHIN on Mar 13, 2016
Latest reply on Mar 16, 2016 by soledad
hello,
Using a USB3300 trying to use ulpi hs mode,
MQX 3.8 that supports external ulpi hs?
If that support is apon the MQX need to upgrade?
The purpose is created using the USB3300 NAND flash and SD card as a mass storage device
NAND Flash and SD card both want to look in the window
In that setting, where you want to use an external ulpi?
Different questions
OTG is that the HOST, DEVICE both support?
When connected to a Windows USB3300 alone device name is what?
