[Yocto BSP 1.8_ga] i.MX6DP The USB/USB OTG port cannot automatic mount the directory
Question asked by charles huang on Mar 14, 2016
Latest reply on Mar 14, 2016 by charles huang
When the USB disk is inserted USB/USB OTG port, it cannot automatic mount the directory.
But the device can detect this device (/dev/sda).
Console log:
     1) log of the USB disk is inserted USB port:
usb 1-1.4: new high-speed USB device number 3 using ci_hdrc
usb-storage 1-1.4:1.0: USB Mass Storage device detected
scsi1 : usb-storage 1-1.4:1.0
scsi 1:0:0:0: Direct-Access     JetFlash Transcend 16GB   8.07 PQ: 0 ANSI: 4
sd 1:0:0:0: [sda] 30530688 512-byte logical blocks: (15.6 GB/14.5 GiB)
sd 1:0:0:0: [sda] Write Protect is off
sd 1:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
usb 1-1.4: reset high-speed USB device number 3 using ci_hdrc
sd 1:0:0:0: [sda] Media Changed
sd 1:0:0:0: [sda]
Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
sd 1:0:0:0: [sda]
Sense Key : Unit Attention [current]
Info fld=0x0
sd 1:0:0:0: [sda]
Add. Sense: Not ready to ready change, medium may have changed
sd 1:0:0:0: [sda] CDB:
Read(10): 28 00 00 00 00 00 00 00 08 00
end_request: I/O error, dev sda, sector 0
Buffer I/O error on device sda, logical block 0
sda: unable to read partition table
hub 1-1:1.0: cannot reset port 4 (err = -71)
usb 1-1.4: USB disconnect, device number 3
sd 1:0:0:0: [sda] READ CAPACITY failed
sd 1:0:0:0: [sda]
Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
sd 1:0:0:0: [sda] Sense not available.
sd 1:0:0:0: [sda] Write Protect is on
sd 1:0:0:0: [sda] No Caching mode page found
sd 1:0:0:0: [sda] Assuming drive cache: write through
sd 1:0:0:0: [sda] Attached SCSI removable disk
sd 1:0:0:0: [sda] Asking for cache data failed
scsi 1:0:0:0: [sda] Assuming drive cache: write through
usb 1-1.4: new high-speed USB device number 4 using ci_hdrc
scsi2 : usb-storage 1-1.4:1.0
scsi 2:0:0:0: Direct-Access     JetFlash Transcend 16GB   8.07 PQ: 0 ANSI: 4
sd 2:0:0:0: [sda] 30530688 512-byte logical blocks: (15.6 GB/14.5 GiB)
sd 2:0:0:0: [sda] Write Protect is off
sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
sda: sda1
sd 2:0:0:0: [sda] Attached SCSI removable disk
usb 1-1.4: reset high-speed USB device number 4 using ci_hdrc
sd 2:0:0:0: [sda] Media Changed
sd 2:0:0:0: [sda]
sd 2:0:0:0: [sda]
Info fld=0x0
sd 2:0:0:0: [sda]
sd 2:0:0:0: [sda] CDB:
Read(10): 28 00 00 00 00 20 00 00 18 00
end_request: I/O error, dev sda, sector 32
Buffer I/O error on device sda, logical block 4
Buffer I/O error on device sda, logical block 5
Buffer I/O error on device sda, logical block 6
sda: sda1
root@:~#
root@:~# df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root       3.4G  3.3G     0 100% /
devtmpfs        503M   76K  503M   1% /dev
tmpfs            40K     0   40K   0% /mnt/.psplash
tmpfs           503M  256K  503M   1% /run
tmpfs           503M   96K  503M   1% /var/volatile
/dev/mmcblk0p1  8.0M  5.4M  2.7M  67% /run/media/mmcblk0p1
/dev/mmcblk2p1  8.0M  5.4M  2.7M  67% /run/media/mmcblk2p1
/dev/mmcblk0p2  3.4G  1.5G  1.7G  47% /run/media/mmcblk0p2
root@:~# ls /dev/sda
sda   sda1
     2) log of the USB disk is inserted USB OTG port:
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 2
ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
usb 2-1: new high-speed USB device number 2 using ci_hdrc
usb-storage 2-1:1.0: USB Mass Storage device detected
scsi1 : usb-storage 2-1:1.0
sda: sda1
usb 2-1: reset high-speed USB device number 2 using ci_hdrc
sd 1:0:0:0: [sda]
sd 1:0:0:0: [sda]
Info fld=0x0
sd 1:0:0:0: [sda]
Read(10): 28 00 01 d1 dc 7d 00 00 01 00
end_request: I/O error, dev sda, sector 30530685
Buffer I/O error on device sda, logical block 3816335
sda: sda1
FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
root@:~#
root@:~# df -h
sda   sda1
Can you help me to solve this issue?
Thank you.
Alex
