Kinetis KV46F256 NMI and reset pin question!
jeffzxg
hi everyone !
          my question is how to disable nmi interrupt and how to disable reset pin. thanks!
Hello Zhang,
You can use the FOPT register of the NMI_DIS bit to disable the NMI fucntion :
It sees the reset pin can not be disabled , for the pin is a dedicated pin for resert :
Hope it helps
Alice Yang
