about PE  FLASH1_Erase method of KEAZ128
Question asked by Jason Zhang on Mar 10, 2016
Latest reply on Mar 15, 2016 by Jason Zhang
I can't find a function for erase sector in the componet methods, is it right?
If I try to erase 0x4000 to (128k-0x4000) memory,
can I do like this of below?
pFlash_Device = FLASH1_Init(NULL);
(void) FLASH1_Erase(pFlash_Device,0x4000,0x1C000);
And is there any typical usage for the function of below.
**     Method      :  FLASH1_Erase (component FLASH_LDD)
**     @brief
**         This method sets up a flash memory erase operation. The
**         operation itself is performing by defined batches (property
**         [Erase batch size]) by periodical calling the component抯
**         Main method in the user application (higher level OS service)
**         or by the component抯 ISR, if an component抯 interrupt
**         service is enabled.
**     @param
**         DeviceDataPtr   - Device data structure
**                           pointer returned by [Init] method.
**     @param
**         FromAddress     - Address of the flash
**                           memory area (the first erase sector is the
**                           sector the given address belongs to) to be
**                           erased.
**     @param
**         Size            - Size of the flash memory area (in bytes)
**                           to be erased. The flash memory is erased by
**                           the erase sectors. The first erased sector
**                           is a sector the address specified by the
**                           input parameter Address belongs to. The
**                           last erased sector is a sector the address
**                           calculated like an addition of the address
**                           specified by the input parameter Address
**                           and the size specified by the input
**                           parameter Size belongs to.
**     @return
**                         - Error code
**                           ERR_OK - OK
**                           ERR_DISABLED - Component is disabled
**                           ERR_SPEED - This device does not work in
**                           the active clock configuration
**                           ERR_BUSY - Some flash memory operation is
**                           already in progress
**                           ERR_PARAM_ADDRESS - Desired flash memory
**                           area is out of allowed range or is not
**                           aligned to erasable units' bounderies
**                           ERR_NOTAVAIL - When Safe launch and wait
**                           mode is enabled (property Safe launch and
**                           wait) and safe routine location is defined
**                           in runtime (property Safe routine location)
**                           and the safe routine location has not been
**                           specified yet (the SetSafeRoutineLocation
**                           method has not been used to define the
**                           location the safe routine will be copied to).
LDD_TError FLASH1_Erase(LDD_TDeviceData *DeviceDataPtr, LDD_FLASH_TAddress FromAddress, LDD_FLASH_TDataSize Size)
  FLASH1_TDeviceDataPtr DevDataPtr = (FLASH1_TDeviceDataPtr)DeviceDataPtr;
  LDD_TError Result;
  Result = CheckStateAndRange(DevDataPtr, FromAddress, Size);
  if (Result != ERR_OK) {
    return Result;
  DevDataPtr->CurrentOperation = LDD_FLASH_ERASE;
  DevDataPtr->CurrentOperationStatus = LDD_FLASH_START;
  DevDataPtr->CurrentDataSize = Size;
  /* FTMRE_PDD_CMD_ERASE_FLASH_SECTOR requires sector address to be 4 bytes aligned  */
  DevDataPtr->CurrentFlashAddress = FromAddress & ~(uint32_t)FLASH1_FLASH_WRITABLE_UNIT_MASK;
  FTMRE_PDD_SetCommand(FTMRE_BASE_PTR, FTMRE_PDD_CMD_ERASE_FLASH_SECTOR);
  return ERR_OK;
Thank you!
Jason
