imx6 android4.3 can't connect  bluetooth remotectl
jinxinxin163
Recently I  hava been debuging  the bluetooth remotectl  ^_^
I make  all the  debug log of bluedroid stack show(please refer to the attachment),  but not clearly error info  can help me except that:
The host controller receive disconnected event (0x05) asynchronously  and the reason is  0x16(Connection Terminated By Local Host)
** Function btu_hcif_process_event
** Description      This function is called when an event is received from   the Host Controller.
void btu_hcif_process_event (UINT8 controller_id, BT_HDR *p_msg)
case HCI_DISCONNECTION_COMP_EVT:  //value is 0x05 -- Occurs when a connection has been disconnected.
  btu_hcif_disconnection_comp_evt (p, hci_evt_len);
break;
reason: HCI_ERR_CONN_CAUSE_LOCAL_HOST
#define HCI_ERR_CONN_CAUSE_LOCAL_HOST 0x16  //  Connection Terminated By Local Host
What does this mean? Can we locate the rootcause with this error?
And from the log file, I can find that:   (00025ba100db is mac addr of the bluetooth remotectl)
D/bt-att ( 3110): connected is TRUE reason=1                           //connnected
D/bt-att  ( 3110): gatt_get_ch_state: ch_state=4
E/bt-att  ( 3110): connection already up, ignore it
D/bt-att  ( 3110): gatt_update_app_use_link_flag  is_add=1 chk_link=0
D/bt-att  ( 3110): gatt_update_app_hold_link_status found=1[1-found] idx=0 gatt_if=3 is_add=1
I/bt-att  ( 3110): GATT_GetConnIdIfConnected status=1
D/bt-btif ( 3110): bta_gattc_conn server cache state=0
D/bt-btif ( 3110): bta_gattc_conn conn_id=3
I/bt-att  ( 3110): GATT_GetConnectionInfor conn_id=3
I/bt-l2cap( 3110): L2CA_EnableUpdateBleConnParams - BD_ADDR 00025ba100db enable 0 current upd state 1
D/bt-btif ( 3110): bta_gattc_cache_open conn_id=3
D/bt-btif ( 3110): bta_dm_gattc_callback event = 2
D/bt-btif ( 3110): DM Search state= 3 search_cb.peer_dbaddr: [00025ba100db] connected_bda= [00025ba100db]
D/bt-btif ( 3110): BTA_GATTC_OPEN_EVT conn_id = 3 client_if=3 status = 0
I/bt-btif ( 3110): BTA got event 0x1f12
D/bt-btif ( 3110): bta_gattc_ci_open conn_id=3 server state=1
I/bt-btif ( 3110): BTA got event 0x1f08
I/bt-btif ( 3110): BTA got event 0x1f13
D/bt-btif ( 3110): bta_gattc_ci_load conn_id=3 load status=138
D/bt-btif ( 3110): bta_gattc_start_discover conn_id=3 p_clcb->p_srcb->state = 3
I/bt-btm  ( 3110): BTM_InqDbRead: bd addr [00025ba100db]
D/bt-btm  ( 3110): btm_find_dev_type - device_type = 2 addr_type = 0
I/bt-att  ( 3110): GATTC_Discover conn_id=3 disc_type=1
E/bt-att  ( 3110):  ### GATTC_Discover debug 1
I/bt-btif ( 3110): HAL bt_hal_cbacks->bond_state_changed_cb
I/BluetoothBondStateMachine( 3110): bondStateChangeCallback: Status: 0 Address: 00:02:5B:A1:00:DB newState: 2
D/BluetoothAdapterProperties( 3110): Adding bonded device:00:02:5B:A1:00:DB
I/BluetoothBondStateMachine( 3110): Bond State Change Intent:00:02:5B:A1:00:DB OldState: 11 NewState: 12
D/HidService( 3110): getHidService(): returning com.android.bluetooth.hid.HidService@41ce0ed8
D/bt-btif ( 3110): cmd.id:4
D/btif_config_util( 3110): btif_config_save_file(L153): in file name:/data/misc/bluedroid/bt_config.new
W/BluetoothEventManager( 3038): CachedBluetoothDevice for device 00:02:5B:A1:00:DB not found, calling readPairedDevices().
D/BluetoothAdapterService(1103915440)( 3110): Get Bonded Devices being called
D/BluetoothAdapterProperties( 3110): getBondedDevices: length=1
D/BluetoothDiscoverableEnabler( 3038): handleModeChanged(): mode = 21
D/HidService( 3110): Saved priority 00:02:5B:A1:00:DB = 100
W/BackupManagerService( 2513): dataChanged but no participant pkg='com.android.providers.settings' uid=1002
I/BluetoothBondStateMachine( 3110): StableState(): Entering Off State
E/bt-att  ( 3110): ### gatt_act_discovery debug  1
E/bt-att  ( 3110): ### gatt_act_discovery debug  2
D/bt-att  ( 3110):  ### attp_send_cl_msg op_code = 16
I/bt-l2cap( 3110): L2CA_SendFixedChnlData()  CID: 0x0004  BDA: 00025ba100db
D/bt-btif ( 3110): HC lib lpm deassertion return 0
D/bt-l2cap( 3110): ###  receive reason 16 //disconnected
W/bt-l2cap( 3110): ### l2cu_release_lcb debug 1
D/bt-l2cap( 3110): l2cu_release_ccb: cid 0x0004  in_use: 1
D/bt-att  ( 3110): GATT   ATT protocol channel with BDA: 00025ba100db is disconnected
D/bt-att  ( 3110): gatt_is_bda_in_the_srv_chg_clt_list :00-02-5b-a1-00-db
D/bt-att  ( 3110): bda is in the srv chg clt list
D/bt-att  ( 3110): gatt_cleanup_upon_disc
D/bt-att  ( 3110): found p_tcb
D/bt-att  ( 3110): found p_clcb conn_id=3 clcb_idx=0
D/bt-att  ( 3110): gatt_end_operation status=133 op=1 subtype=1
D/bt-btif ( 3110): bta_gattc_disc_cmpl conn_id=3
W/bt-l2cap( 3110): L2CA_EnableUpdateBleConnParams - unknown BD_ADDR 00025ba100db
D/bt-btif ( 3110): bta_gattc_search conn_id=3
D/bt-btif ( 3110): bta_dm_gattc_callback event = 6
D/bt-btif ( 3110): bta_dm_gatt_disc_complete conn_id = 3
D/bt-att  ( 3110): gatt_free_pending_ind
D/bt-att  ( 3110): gatt_free_pending_enc_queue
D/bt-att  ( 3110): found p_reg tcb_idx=0 gatt_if=1  conn_id=0x1
I/bt-att  ( 3110): gatt_profile_connect_cback: from 00025ba100db connected:0 conn_id=1 reason = 0x0016
D/bt-att  ( 3110): found p_reg tcb_idx=0 gatt_if=2  conn_id=0x2
D/bt-att  ( 3110): found p_reg tcb_idx=0 gatt_if=3  conn_id=0x3
D/bt-btif ( 3110): bta_gattc_conn_cback: cif = 3 connected = 0 conn_id = 3 reaosn = 0x0016
D/bt-att  ( 3110): exit gatt_cleanup_upon_disc
D/bt-att  ( 3110): ATT disconnected
I/bt-smp  ( 3110): SMDBG l2c smp_connect_cback
D/bt-btm  ( 3110): btm_acl_removed
D/bt-btm  ( 3110): btm_bda_to_acl found
D/bt-btm  ( 3110): btm_acl_report_role_change
D/bt-btm  ( 3110): btm_acl_update_busy_level
D/bt-btm  ( 3110): BTM_BLI_ACL_DOWN_EVT
D/bt-btm  ( 3110): acl hci_handle=128 is_le_link=1 connectable_mode=0x0 link_role=0
D/bt-btm  ( 3110): before update p_dev_rec->sec_flags=0x9e
D/bt-btm  ( 3110): LE link down
D/bt-btm  ( 3110): Bonded
D/bt-btm  ( 3110): after update p_dev_rec->sec_flags=0x9a
D/bt-btm  ( 3110): btm_acl_resubmit_page
E/bt-btm  ( 3110): btm_sec_disconnected - Clearing Pending flag
I/bt-btm  ( 3110): btm_sec_disconnected() sec_req:x0  State: 0   reason:22 bda:00025ba100db RName:ANYCON 4.0
I/bt-btm  ( 3110): before Update sec_flags=0x9a
D/bt-btm  ( 3110): btm_ble_update_mode_operation adv_mode = 0
I/bt-btm  ( 3110): after Update sec_flags=0x98
I/bt-btif ( 3110): BTA got event 0x207
I/bt-btif ( 3110): bta_dm_search_sm_execute state:3, event:0x207
D/bt-btif ( 3110): bta_dm_disc_result
I/bt-btif ( 3110): BTA got event 0x1f07
D/bt-btif ( 3110): bta_gattc_close conn_id=3
I/bt-att  ( 3110): GATT_Disconnect conn_id=3
D/bt-btif ( 3110): bta_dm_gattc_callback event = 5
I/bt-btif ( 3110): bta_dm_gattc_callback event = 5
D/bt-btif ( 3110): BTA_GATTC_CLOSE_EVT reason = 22
D/bt-btif ( 3110): btif_dm_search_services_evt:(result=0x1, services 0x0)
D/bt-btif ( 3110): bta_dm_gatt_disc_complete conn_id = 65535
D/bt-btif ( 3110): BTA got event 0x1f10
I/bt-btif ( 3110): BTA got event 0x1f10
E/bt-btif ( 3110): Unknown conn ID: 3
I/bt-btif ( 3110): BTA got event 0x108
E/ ( 3110): ### ASSERT : external/bluetooth/bluedroid/main/../btif/src/btif_dm.c line 1125 storing remote services failed (1) ###
I/bt-btif ( 3110): bta_dm_sm_execute event:0x8
I/bt-btif ( 3110): btm_get_acl_disc_reason_code
D/bt-btm  ( 3110): btm_get_acl_disc_reason_code
I/bt-l2cap( 3110): L2CA_SetDesireRole() new:x1, disallow_switch:0
I/bt-btif ( 3110): BTA got event 0x206
I/bt-btif ( 3110): bta_dm_search_sm_execute state:3, event:0x206
D/bt-btif ( 3110): bta_dm_search_cmpl
I/bt-btif ( 3110): bta_dm_search_sm_execute state:0, event:0x207
E/BluetoothRemoteDevices( 3110): devicePropertyChangedCallback: bdDevice: 00:02:5B:A1:00:DB, value is empty for type: 3
I/bt-btif ( 3110): btif_dm_upstreams_cback  ev: BTA_DM_LINK_DOWN_EVT
D/bt-btif ( 3110): BTA_DM_LINK_DOWN_EVT. Sending BT_ACL_STATE_DISCONNECTED
I/bt-btif ( 3110): HAL bt_hal_cbacks->acl_state_changed_cb
D/BluetoothRemoteDevices( 3110): aclStateChangeCallback: State:DisConnected to Device:00:02:5B:A1:00:DB
I/bt-btif ( 3110): btif_dm_upstreams_cback  ev: BTA_DM_BUSY_LEVEL_EVT
I/bt-btif ( 3110): btif_dm_search_services_evt:  event = 4
Wish your constructive suggestions. Thank you!
Original Attachment has been moved to: bluetooth.log.zip
