How to map a ftm interrupt vector function by driver code
Question asked by Jason Zhang on Mar 9, 2016
Latest reply on Mar 11, 2016 by Jason Zhang
By PE the ftm interrupt event  code can write in the function of below.
How can I make such a funtion in the driver code(without PE) that attached.
Thanks!
MCU :KEAZ128
**     Event       :  Timer_OnInterrupt (module Events)
**     Component   :  Timer [FreeCntr]
**     @brief
**         This event is called when a compare matches the counter
**         value (if compare or reload is selected as a interrupt
**         source) or a counter overflows (for free-running devices).
**         It is valid only when the component is enabled - <"Enable">
**         and the events are enabled - <"EnableEvent">. The event is
**         available only if <Interrupt service/event> is enabled.
void Timer_OnInterrupt(void)
  /* Write your code here ... */
  system_clock_Acc++;
Jason
Original Attachment has been moved to: ftm.c.zip
Original Attachment has been moved to: ftm.h.zip
