How to install Kernel table of isr.c Example?
Question asked by Norberto Jiménez on Mar 9, 2016
Latest reply on Mar 9, 2016 by Daniel Chen
I am working in the example project of ISR. I am using TWRK60N512. I compiled isr library and the project; but, when I tried to debug or run isr.c, Terminal received the next:
====================== ISR Example =======================
Press the SW1 to blink LED1, press it again to turn it off
Install interrupt handler to hardware vector table failed.
So, I can consider that there is a problem in the code in this part:
    /* Install the interrupt directly to the vector table in the processor. */
    if(! _int_install_kernel_isr(lwgpio_int_get_vector(btn_ptr), btn_kernel_isr))
        printf("Install interrupt handler to hardware vector table failed.\n");
        _task_block();
But I don't know where this example is wrong.
Anybody can help me?
I am confused because I have never change anything of example code. I am ataching the example of MQX 4.2
Original Attachment has been moved to: isr.c.zip
