Subject: Codewarrior usb tap not erasing/ programming with mpc8641d-using CWH-CTP-BASE-HE(USB Warrior)+ CWH-CTP-COP-YE(ADD TIP)   I am using CWH-CTP-BASE-HE(USB Warrior)+ CWH-CTP-COP-YE(ADD TIP) to program MPC8641d based board. Codewarrior IDE Version 8.8
Question asked by shivakumar krishnamurthy on Mar 9, 2016
Latest reply on Mar 11, 2016 by Yiping Wang
I am using CWH-CTP-BASE-HE(USB Warrior)+ CWH-CTP-COP-YE(ADD TIP) to program MPC8641d based board. Codewarrior IDE Version 8.8 is used for flash programming with patch 8.8.6 installed. When USB TAP is connected to the target board, following issues are observed:
1. The Flash programmer is not able to program or erase the programmed sectors Flash.
2. Programmer is able to erase already blank sectors.
3. Programming in already blank sectors also is failing.
4. Sometimes, connection itself is failing with error message Check your JTAG clock speed.
Kindly, clarify the above points and suggest if any software updation is required. If so, please provide download link and instructions for the same.
