The 89LPC936 appears to be end of life. It is really annoying. We knew the others in the series were discontinued last year and started moving designs to the 936 which is relatively easy though still costly. Surely you can keep the 936 going as at least the one variant of this series which could encompass the others without too much change. You can bet we won't be migrating to an NXP ARM device..
