Upgrade problem(Old OSJTAG/OSBDM firmware),need jump 2-pin bootloader header(JM60 IRQ to GND) on a VLG M9S12zvc
kevinphilllips
need jump 2-pin bootloader header(JM60 IRQ to GND) on a VLG M9S12zvc but im not knowing where is this 2-pin jumper, and i cant do nothing until i fix it,
maybe is it a software solution or a good hardware schematic ?
thanks you all in advance !
iggi
Here is the schematic of the demo board:
  VLG-MC9S12ZVC Board Schematics (REV B)
See the sheet 7 of 13 titled OSBDM. There si the J36 jumper and it should be the one you need.
iggi
iggi
iggi
kevinphilllips
That's work perfectly thanks you very much !
