Dear Team
I upgrade the code warier 10.6 it got upgraded successful.
At the start up one pop up came PE debugger Firmware is out of date then I upgrade the PE debugger firmware.
Now PE debugger is not working fine It is getting restart frequently.
Requesting help for the same.
hi,
what P&E tool do you work with?
Jennie Zhang
Hi Jennie Zhang
I am using PE Micro Multilink universal Rev c and CodeWarrior Version: 10.6.4 Build Id:150416
Thanks & Regards,
Charudatta
Hi Charudatta,
please download and update the firmware with latest firmware update utility, up-to-date firmware:
can this help you?
Jennie Zhang
