now my lcd panel can get displayed after boot. I can use uart console to input command in console shell, i think to know if the keyboard driver get installed so that i plug keyboard to directly input command on screen, i input "dmesg | grep keyboard" and get nothing, so how to know keyboard driver get installed or not? (I use core-image-minimal yocto image).
looking forward to reply, thanks.
Hello wz ca,
The keyboard driver is enabled on the core-image-minimal image of the i.MX BSP. However, you may not see the driver enabled until you insert a USB keyboard (make sure to use a USB OTG cable to connect the keyboard).
I hope this helps!
