what is the JRSDIDR in CAAM.
Question asked by MyungJin Hwang on Mar 7, 2016
Latest reply on Mar 8, 2016 by MyungJin Hwang
Dear NXP team.
I have a "IMX6DQ6SDLSRM_security.pdf" doc file.
- Document Number: IMX6DQ6SDLSRM Rev. 0, 03/2013
Question 1. I can not find what is the  JRSDIDR and what does it mean in the doc file.
     B.2.6 Job Ring Registers
     This section describes registers found in each of the job rings. A functional description of
     the job rings can be found in the “Cryptographic Acceleration and Assurance Module
     (CAAM)” chapter.
     If the job ring is allocated to TrustZone SecureWorld (JRSDIDR TZ=1), then the job ring
     registers associated with this ring may only be written via a bus transaction that has ns=0.
     Transactions with ns=1 for job rings owned by TrustZone SecureWorld will be ignored.
Question 2. Input/Output Ring Base Address Register
     There are each 2 Input/Output Ring Base Address Register .
     - IRBAR0, IRBAR1
     - ORBAR0, ORBAR01
     What is the different of IRBAR0, IRBAR1 and ORBAR0, ORBAR01 ?
     - ex) IRBAR0 is for TrustZone SecureWorld and IRBAR1 is for TrustZone Non-SecureWorld ?
MyungJin Hwang
