I have tried to run MQX 4.2 mfs_nandflash demo projeto for TWR-K70F120M, but it fails. The welcoming screen comes up as well as "shell>" prompt with the cursor. But no matter what I type in Terminal, that nothing happens. It remains at the same place and seems not to respond to any command.
Can anybody give me an idea of what is going on? I recompiled all the libraries over and over. No way!
Thanks!
Solved! Go to Solution.
I just found out what was causing the failure in Shell, It was a simple definition in the Shell settings. I just disabled the macro "SHELL_CFG_USES_RTCS" and everything started to work.
Thanks!
Thanks!
