Hi all
Let me confirm a output timing of PMIC_ON_REQ.
I plan to use i.MX6SL and PF0100 and understand that PMIC_ON_REQ's power source is VDD_SNVS_IN.
Which voltage level does VDD_SNVS_IN need to output a PMIC_ON_REQ ?
I concern that PMIC_ON_REQ is output before VDD_SNVS_IN reach their voltage level.
ko-hey
Hi Ko-hey
valid level VDD_SNVS_IN = 2.8-3.3V according to Table 9. Operating Ranges
i.MX6SL Datasheet
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SLCEC.pdf
Hi Igor
Thank you for your reply.
Let me confirm again.
PMIC_ON_REQ will be outputted after VDD_SNVS_IN reach 2.8V.
So it will have never happened that PMIC_ON_REQ outputs their signal before SNVS is rise-up.
Is it correct ?
Ko-hey
Hi Ko-hey
yes in general this is correct, SNVS is correctly working
in voltage range specified by datasheet
Hi Igor
I understand.
Thanks.
Ko-hey
