TEMPMON of i.MX6SLX
TEMPMON of i.MX6SLX
takashitakahash
HI community.
Our customer has question below.
This is a question about TEMPMON.
IMX6SXRM "the TEMPMON memory map are description in" Page 4056 of 63.3 but not in this description of the specifications of TEMPMON_TEMPSENSEx_SET , TEMPMON_TEMPSENSEx_CLR, and TEMPMON_TEMPSENSEx_TOG.
For those, please inform me.
Best.
Hi Takashi
register TEMPMON_TEMPSENSE is described in sect.
63.3.1 Tempsensor Control Register 0 (TEMPMON_TEMPSENSE0n).
Meaning of other registers are the same as TEMPMON_TEMPSENSE:
_SET - set specific bit in TEMPMON_TEMPSENSE
_CLR - clears bit
_TOG - toggle bit
Hi Takashi
_CLR - clears bit
_TOG - toggle bit
takashitakahash
Hi  igor.
thank you for your answer.
Please tell me an additional
My understanding is each registers are  Bit Field configuration is the same and according to Address change.
Could you tell me a specific example of the example of use or value of each Register.
Best.
Hi Takashi
understanding is correct, examples can be found in SDK, attached
is imx_uart.c for uart.
takashitakahash
Hi igor
Thank you for your reply.
Best.
