MPC5606B : EMIOS under SAIC and MCB Mode
raghavendrapura
Please provide a application note or sample code to use EMIOS under SAIC(Single Action Input Capture) and MCB(Modulus Counter Buffered) mode.
I need to measure the no of rising edges and also to count the number of pulses on the input pin using EMIOS module and also to trigger an interrupt based on it.
Please assist.
Raghavendra P
Tags (2)
PetrS
see attached example.
BR, Petr
