Hey Guys
I have just enabled the VPU Decoder for our Webrtc/ Opentok based Video chat application.
There are couple of issues Im trying to debug:
1. The color format: Although Im able to distinguish objects on the screen, the image appears to be in grayscale with green vertical lines. Opentok expects an output format of YUV420Planar. and I have a programmed the output port with the same.
2. Huge latency of 8s between the expected and actual. below is the logs, for some reason i suspect the frames are being skipped because the output buffer is not draining fast enough, below are the logs:
If you are familiar with the Openmax IL Architecture, the time between
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based EmptyBuffer 0x78c8b0c8.
and
I/ACodec ( 1064): frame PTS 2125102309: 8033
As seen above: The complete Decoding cycle for a given frame is roughly 6-8 ms, which should be decent enough for streaming 1080p at 30fps?
I see that a lot of the frames are getting skipped:
I/OMXPlayer( 129): LEVEL: 1 FUNCTION: OMX_ERRORTYPE VideoFilter::ProcessInputBuffer() LINE: 585
I/OMXPlayer( 129): Filter In port has #0 buffers.
I/OMXPlayer( 129): LEVEL: 1 FUNCTION: OMX_ERRORTYPE VideoFilter::ProcessOutputBuffer() LINE: 642
I/OMXPlayer( 129): Filter Out port has #4 buffers.
I/OMXPlayer( 129): LEVEL: 1 FUNCTION: virtual OMX_ERRORTYPE VideoFilter::ProcessDataBuffer() LINE: 424
I/OMXPlayer( 129): ProcessDataBuffer
my initial suspicion was that the OMX Component was not prioritized, but looks like working fine.
What would be your initial thoughts. Why does it say Filter In Port has #0 buffers, although the frames are arriving at 30 FPS.
any inputs really appreciated here:
Kushal
we are not using the "OMX.Freescale.std.parser.streaming.sw-based" component. hence the obove code will not be executed.
currently using the "OMX.Freescale.std.vp8.hw-based" component.
Currently we have a cache buffer which size is 4 seconds data, you can reduce this cache size to lower the latency.
external/fsl_imx_omx/OpenMAXIL/src/component/streaming_parser/StreamingParser.cpp,
#define PACKET_CACHE_SIZE (4*OMX_TICKS_PER_SECOND)
more comprehensive set of logs below:
I/opentok-session( 1117): New signal with data: 1 is received
D/opentok-hwdecode( 1117): Disposing codec
D/opentok-hwdecode( 1117): Frame size: 1280x720
D/opentok-hwdecode( 1117): Using COLOR_FormatYUV420SemiPlanar
E/ACodec ( 1117): Now uninitialized
I/OMXClient( 1117): Using client-side OMX mux.
I/OMXPlayer( 129): ConstructComponent
I/OMXPlayer( 129): OMX_ERRORTYPE VpuDecoderInit(OMX_HANDLETYPE):
I/OMXPlayer( 129): VpuDecoder::VpuDecoder():
I/OMXPlayer( 129): inside InitComponent
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::InitFilterComponent():
I/OMXPlayer( 129): inside SetDefaultSetting nInPortFormatCnt 1, eInPortPormat[i] 21
I/OMXPlayer( 129): inside SetDefaultSetting nOutPortFormatCnt 1, eOutPortPormat[i] 19
E/IOMX ( 1117): set parameter 16777239
I/OMXPlayer( 129): Do set parameter 16777239
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetParameter(OMX_INDEXTYPE, OMX_PTR): nParamIndex=0x1000017
I/OMXPlayer( 129): OMX_ERRORTYPE VpuDecoder::SetRoleFormat(OMX_STRING): role: video_decoder.vp8
I/ACodec ( 1117): Send reorder config(0) to VPU
E/IOMX ( 1117): set parameter 2130706489
I/OMXPlayer( 129): Do set parameter 2130706489
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetParameter(OMX_INDEXTYPE, OMX_PTR): nParamIndex=0x7F000039
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetParameter(OMX_INDEXTYPE, OMX_PTR): set OMX_IndexParamVideoDecReorderDisable: disabled: 0
E/IOMX ( 1117): get parameter 100663297
I/OMXPlayer( 129): Do get parameter 100663297
E/ACodec ( 1117): eColorFormat 21, colorFormat 21
E/IOMX ( 1117): set parameter 100663297
I/OMXPlayer( 129): Do set parameter 100663297
E/ACodec ( 1117): [OMX.Freescale.std.video_decoder.vpx.hw-based] returning after setparameter9
E/IOMX ( 1117): get parameter 33554433
I/OMXPlayer( 129): Do get parameter 33554433
E/IOMX ( 1117): set parameter 33554433
I/OMXPlayer( 129): Do set parameter 33554433
I/OMXPlayer( 129): PortFmtChanged 0
E/IOMX ( 1117): sendCommand 0
I/OMXPlayer( 129): Sending Command[cmd:0, param: 2, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): Sending Command[cmd:0, param: 2, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based] done.
E/IOMX ( 129): onTransact Send command
E/IOMX ( 1117): IOMX use Buffer 0
I/OMXPlayer( 129): Processing Command[cmd:0, param: 2, data: 0] in Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): LEVEL: 1 FUNCTION: OMX_ERRORTYPE Port::UseBuffer(OMX_BUFFERHEADERTYPE**, OMX_PTR, OMX_U32, OMX_U8*) LINE: 237
I/OMXPlayer( 129): UseBuffer
I/OMXPlayer( 129): inside DoAllocateBuffer
I/OMXPlayer( 129): virtual void* VpuDecoder::AllocateOutputBuffer(OMX_U32): state: 1
I/OMXPlayer( 129): Sending Command[cmd:0, param: 3, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): Sending Command[cmd:0, param: 3, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based] done.
I/OMXPlayer( 129): Processing Command[cmd:0, param: 3, data: 0] in Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): Process Command [cmd:0, param: 3, data: 0] finished.
E/ACodec ( 1117): Resume before portFillThisBuffer, submitting output buffers
E/OMXNodeInstance( 129): Before calling OMX_FillThisBuffer from fillBuffer
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef1c8.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef1c8]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef378.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef378]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef5b0.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef5b0]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef798.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef798]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef960.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef960]
E/OMXNodeInstance( 129): Before calling EmptyThisBuffer from emptyBuffer
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based EmptyBuffer 0x790eeca8.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Input buffer[0x790eeca8]
E/IOMX ( 129): onTransact EMPTY_BUFFER
E/IOMX ( 1117): empty Buffer 2508
I/OMXPlayer( 129): Filter In port has #1 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetInputBuffer(OMX_PTR, OMX_S32, OMX_BOOL): state: 1, size: 2508, last: 0
I/OMXPlayer( 129): Filter Out port has #5 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 1, buffer: 0x70B4E000
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 1, InBuf: 0x6B3B6000, data size: 2508, bInEos: 0
I/OMXPlayer( 129): vpu lib version : rel.major.minor=27.5.4
I/OMXPlayer( 129): vpu fw version : rel.major.minor=1.3.1
I/OMXPlayer( 129): OMX_ERRORTYPE OpenVpu(VpuDecHandle*, VpuMemInfo*, VpuCodStd, OMX_S32, OMX_S32, OMX_COLOR_FORMATTYPE, OMX_S32, VPUCompSemaphor, OMX_BOOL): codec format: 14
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): pBitstream=0x6B3B6000, readbytes=2508
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): bufRetCode: 0x201
I/OMXPlayer( 129): open temp.bit failure
I/OMXPlayer( 129): FilterBufRetCode VpuDecoder::ProcessVpuInitInfo(): original init info: [top,left,bottom,right]=[0,0,240,320],
I/OMXPlayer( 129): potential risk for sInFmt [widthxheight]: [320x240]
I/OMXPlayer( 129): FilterBufRetCode VpuDecoder::ProcessVpuInitInfo(): Init OK, [width x height]=[320 x 240]
I/OMXPlayer( 129): FilterBufRetCode VpuDecoder::ProcessVpuInitInfo(): [top,left,width,height]=[0,0,320,240],
I/OMXPlayer( 129): nOutBufferCntDec:7 ,nPadWidth: 320, nPadHeight: 256
I/OMXPlayer( 129): FilterBufRetCode VpuDecoder::ProcessVpuInitInfo(): ratio: width: 0x10000, height: 0x10000
I/OMXPlayer( 129): OutputFmtChanged 203518729
I/OMXPlayer( 129): FilterBufRetCode VpuDecoder::ProcessVpuInitInfo(): enter wait frame state
E/IOMX ( 1117): sendCommand 2
I/OMXPlayer( 129): Sending Command[cmd:2, param: 1, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): Sending Command[cmd:2, param: 1, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based] done.
I/OMXPlayer( 129): Processing Command[cmd:2, param: 1, data: 0] in Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::FlushOutputBuffer(): state: 3
I/OMXPlayer( 129): Filter Out port has #0 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::FreeOutputBuffer(OMX_PTR):
E/IOMX ( 1117): sendCommand 3
I/OMXPlayer( 129): Sending Command[cmd:3, param: 1, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): Sending Command[cmd:3, param: 1, data: 0] to Component[OMX.Freescale.std.video_decoder.vp8.hw-based] done.
I/OMXPlayer( 129): Processing Command[cmd:3, param: 1, data: 0] in Component[OMX.Freescale.std.video_decoder.vp8.hw-based].
I/OMXPlayer( 129): virtual void* VpuDecoder::AllocateOutputBuffer(OMX_U32): state: 3
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790e6eb0.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790e6eb0]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790e70a0.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790e70a0]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef060.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef060]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef8d8.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef8d8]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef100.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef100]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790ef238.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790ef238]
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based FillBuffer 0x790e89d0.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Output buffer[0x790e89d0]
I/OMXPlayer( 129): Filter Out port has #7 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6ED5B000
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 3, InBuf: 0xFFFFFFFF, data size: 0, bInEos: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): waiting frames ready, return and do nothing
I/OMXPlayer( 129): Filter Out port has #6 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6ED7A000
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6ED99000
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6F124000
I/OMXPlayer( 129): Filter Out port has #3 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6F143000
I/OMXPlayer( 129): Filter Out port has #2 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6F162000
I/OMXPlayer( 129): Filter Out port has #1 buffers.
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 3, buffer: 0x6F181000
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::InitFilter():
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 5, InBuf: 0xFFFFFFFF, data size: 0, bInEos: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): pBitstream=0x0, readbytes=0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): bufRetCode: 0x5
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): return OMX_ErrorNone
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetOutputBuffer(void**, OMX_S32*): state: 6
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetOutputBuffer(void**, OMX_S32*): return output: 0x6ED5B000, nFreeOutBufCntDec: 7
I/OMXPlayer( 129): open temp.yuv failure
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetOutputBuffer(OMX_PTR): state: 5, buffer: 0x6ED5B000
I/OMXPlayer( 129): set output: 0x6ED5B000 , nFreeOutBufCntDec: 7
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): bufRetCode: 0x109
D/opentok-hwdecode( 1117): We waited too much time. Remaining frames: 1
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based EmptyBuffer 0x790ef000.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Input buffer[0x790ef000]
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetInputBuffer(OMX_PTR, OMX_S32, OMX_BOOL): state: 5, size: 65, last: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 5, InBuf: 0x6B41A000, data size: 65, bInEos: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): pBitstream=0x6B41A000, readbytes=65
E/IOMX ( 1117): empty Buffer 65
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetOutputBuffer(void**, OMX_S32*): return output: 0x6ED7A000, nFreeOutBufCntDec: 7
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetConfig(OMX_INDEXTYPE, OMX_PTR): nParamIndex=0x700000F,
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetConfig(OMX_INDEXTYPE, OMX_PTR): [top,left,width,height]=[0,0,320,240],
D/opentok-hwdecode( 1117): MediaCodec.INFO_OUTPUT_FORMAT_CHANGED
D/opentok-hwdecode( 1117): Frame size: 320x256
D/opentok-hwdecode( 1117): Stride: 320
D/opentok-hwdecode( 1117): Slice-height: 0
D/opentok-hwdecode( 1117): Crop-left: 0
D/opentok-hwdecode( 1117): Crop-top: 0
D/opentok-hwdecode( 1117): Key color format: 19
I/opentok-subscriberkit( 1117): Subscriber with streamId: 1A94FEB4-75A2-486E-AA5C-6DA01A22F169 is connected
I/opentok-subscriberkit( 1117): First frame received from Subscriber with streamId: 1A94FEB4-75A2-486E-AA5C-6DA01A22F169
E/IOMX ( 1117): empty Buffer 51
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetInputBuffer(OMX_PTR, OMX_S32, OMX_BOOL): state: 5, size: 51, last: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 5, InBuf: 0x6B3B6000, data size: 51, bInEos: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): pBitstream=0x6B3B6000, readbytes=51
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetOutputBuffer(void**, OMX_S32*): return output: 0x6ED99000, nFreeOutBufCntDec: 6
E/BufferQueue( 126): [SurfaceView] dequeueBuffer: can't dequeue multiple buffers without setting the buffer count
D/opentok-nativerenderer( 1117): VideoRenderOpenGles20: id 0
D/opentok-nativerenderer( 1117): Setup: number of textures 8, size 8192
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based EmptyBuffer 0x790eee90.
I/OMXPlayer( 129): OMX.Freescale.std.video_decoder.vp8.hw-based Sending Input buffer[0x790eee90]
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetInputBuffer(OMX_PTR, OMX_S32, OMX_BOOL): state: 5, size: 53, last: 0
E/IOMX ( 1117): empty Buffer 53
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 5, InBuf: 0x6B3E8000, data size: 53, bInEos: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): pBitstream=0x6B3E8000, readbytes=53
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::GetOutputBuffer(void**, OMX_S32*): return output: 0x6F124000, nFreeOutBufCntDec: 5
E/IOMX ( 1117): empty Buffer 57
I/OMXPlayer( 129): virtual OMX_ERRORTYPE VpuDecoder::SetInputBuffer(OMX_PTR, OMX_S32, OMX_BOOL): state: 5, size: 57, last: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): state: 5, InBuf: 0x6B41A000, data size: 57, bInEos: 0
I/OMXPlayer( 129): virtual FilterBufRetCode VpuDecoder::FilterOneBuffer(): pBitstream=0x6B41A000, readbytes=57
