Hi. I am using K30VLL7 to drive my 5V LCD. The problem is when I want to setup from the processor expert, it didnt allow me to set 5V LCD. It says " 5V LCD not supported by HW". What does it mean?? But from the datasheet, as I understand,this micon is able to drive 5V LCD. Is there any other setting that I should change?
I use CPSEL=1, VSUPPLY=1, RVEN=1. Any other setting that I should set?
Can someone help. TQ
Solved! Go to Solution.
Hi norzilash,
The PE component SegLCD_LDD really have the 5V selection problem, I think it is the PE bug, I will report it to the Processor Expert development team. They will fix it.
Now, you can use the code which is controlled by the register, about the configuration, I have a CW10.6 project for K40D100, you can refer to it.
Wish it helps you!
If you still have question, please contact with me!
Jingjing
Hi norzilash,
Wish it helps you!
Jingjing
Hi Jingjing,
Thanks for the reply and project reference file. TQ. Hope it will help. Thanks a lot.
Thank you,
illa
Hi illa,
You are welcome!
If you still have question, you can let me know!
If this post is answered, please mark the correct answer button, thank you!
Jingjing
