imx6ul ov5640 capture
Question asked by 小辉哥 on Mar 1, 2016
Latest reply on Oct 26, 2016 by fresxc M.fresxc
hi,
I'm testing the camera of i.mx6ul,Test steps are as follows:
insmod /lib/modules/3.14.38-6UL_ga+ge4d0573/kernel/drivers/media/platform/mxc/subdev/mx6s_capture.ko
insmod /lib/modules/3.14.38-6UL_ga+ge4d0573/kernel/drivers/media/platform/mxc/subdev/ov5640_camera.ko
A serial port output:
1-003c supply DOVDD not found, using dummy regulator
1-003c supply DVDD not found, using dummy regulator
1-003c supply AVDD not found, using dummy regulator
CSI: Registered sensor subdevice: ov5640 1-003c
camera ov5640, is found
then,use this command:/unit_tests/mx6s_v4l2_capture.out -d /dev/video1 -m 1
the lcd output is deranged,
Please advise.
Thank you
