Hi. I am using K30VLL7 to drive my 5V LCD. The problem is when I want to setup from the processor expert, it didnt allow me to set 5V LCD. It says " 5V LCD not supported by HW". What does it mean?? But from the datasheet, as I understand,this micon is able to drive 5V LCD. Is there any other setting that I should change?
I use CPSEL=1, VSUPPLY=1, RVEN=1. Any other setting that I should set?
Can someone help. TQ
You are correct that K30 really support 5V LCD as you had known from the manual. I had checked the PE and find the same issue as you mentioned. Seems the component SegLCD_LDD has bugs for 5V LCD. I will check this issue more detail wiith the PE expert team and let you know the result. Sorry for the inconvenience.
