Arduino header on i.MX6UltraLite
giulianofranche
we would like to test the i.MX6UltraLite, but we have a pretty simple question: do we have to solder anything in the arduino header to plug some shields in?
The picture of the board shows that the JTAG connector is in the arduino header area, and I'm afraid I may not have enough space to plug the shield directly on the board
Tags (2)
art
This is optional and use case dependent.
Artur
giulianofranche
Thank you for your answer Artur.
Do we must solder the extenders, or is this optionnal?
art
Artur
art
Yes, you can solder some connector extenders into the Arduino header pads to leave more space under the shield.
Artur
